partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
The speedo worked when last parked, but now nothing works, and found a green/white wire in that area unhooked.
All the rest of my gauges are working correctly. So my assumption would be, it would plug in there somewhere, but not sure where. It's marked signal on the top, and + - on the bottom. Looks like a couple more places on the bottom to hook, and one more on the top to plug in. ![]() ![]() ![]() ![]() ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Actually, the white with a green stripe wire is the park light indicator. It comes on when your park lights are on but the headlights are not. The factory speedo had a green light for that. The high beam indicator is blue and in the tach.
Clay |
partwerks |
Actually, the white with a green stripe wire is the park light indicator. It comes on when your park lights are on but the headlights are not. The factory speedo had a green light for that. The high beam indicator is blue and in the tach. Clay At least the speedo and tach have been converted. I know when things were working, all the lights in the gauges worked, so he must have either got too wire pulling crazy, or something left undone. Thing is, I don't know if that green wire is used on the new system, or no? I had a gentleman on the club here change the guts to the tach so I would work with the Boxster trans. No more cable on it either. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:47 PM |
