Gearup |
Member ![]() ![]() Group: Members Posts: 157 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
Good afternoon,
Was wondering if I could get info and pictures on peoples setups with their boxster s transmissions with the LS motor. Did you use the stock 6 speed Boxster shifter and cables. If so, did you created a pedestal to raise its height (Pics please). If not, what shifter did you use? Did you use a stock pedal cluster? Is there an aftermarket pedal cluster that could be set up for a hydraulic clutch and throttle cable that you have used? I have most everything but the tranny Mount and engine Mount bar. Any input and pics are appreciated. Brett |
Gearup |
Thanks guys. Appreciate any and all input.
Brett |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:41 PM |
