partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
The speedo worked when last parked, but now nothing works, and found a green/white wire in that area unhooked.
All the rest of my gauges are working correctly. So my assumption would be, it would plug in there somewhere, but not sure where. It's marked signal on the top, and + - on the bottom. Looks like a couple more places on the bottom to hook, and one more on the top to plug in. ![]() ![]() ![]() ![]() ![]() |
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,875 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
Where's the ground (brown wire) spade connector for the negative "-" terminal?
partwerks |
Where's the ground (brown wire) spade connector for the negative "-" terminal? I looked to try and see it, but only see the green and white wire. Ultimately, I plan on taking it back for him to see what he did. He took a bunch of wiring out from previous owners over the years. So I don't know what he all did, but was working when I took it in. Getting two different answers on the green and white wire? I would think I need it, as it was just hanging in there, like it should have a place i there somewhere, but I don't just want to plug it in, if I don't know what I'm doing. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:31 PM |
