Speedometer wire |
Speedometer wire |
partwerks |
Oct 8 2021, 08:13 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The speedo worked when last parked, but now nothing works, and found a green/white wire in that area unhooked.
All the rest of my gauges are working correctly. So my assumption would be, it would plug in there somewhere, but not sure where. It's marked signal on the top, and + - on the bottom. Looks like a couple more places on the bottom to hook, and one more on the top to plug in. |
BIGKAT_83 |
Oct 12 2021, 07:07 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
The Boxster S transaxle does not have a VSS signal. It uses the ABS wheel sensors to drive the speedometer. On my car I used a pulse ring on the CV joint for my speedometer.
partwerks |
Oct 12 2021, 07:40 PM
The Boxster S transaxle does not have a VSS signal. It uses the ABS wheel sensors to drive the speedometer. On my car I used a pulse ring on the CV joint for my speedometer. Does the 5 speed Boxster use that system also? I had a sensor by the flange, but may don't work with this trans?? |
partwerks |
Oct 12 2021, 09:23 PM
[quote name='partwerks' date='Oct 12 2021, 05:40 PM' post='2952065']
[quote name='BIGKAT_83' post='2951929' date='Oct 12 2021, 05:07 AM'] The Boxster S transaxle does not have a VSS signal. It uses the ABS wheel sensors to drive the speedometer. On my car I used a pulse ring on the CV joint for my speedometer. [/quote] The sensor from the Boxster 5 speed was installed on the 6 speed. Is this correct? |
Lo-Fi Version | Time is now: 24th September 2024 - 01:05 PM |
