emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,211 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability.
I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw |
Quinn Moore |
Qmoore ![]() ![]() Group: Members Posts: 111 Joined: 13-July 21 From: Lake Geneva, WI Member No.: 25,718 Region Association: Upper MidWest ![]() ![]() |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability. I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw Did you get the tuning kit as well? Does it come with instructions? I guess that's a question for tangerine. Thought I'd I ask about your experience with the kit. (Since I can't seem to follow directions, i.e "Tech Tips 700", "don't mess with the mps!" @dr914 @autoatlanta.com....I did....so, now I'm ready for instructions on how fix the thing I shouldn't have messed with). Good luck, sounds/looks like your close to getting it dialed in. QM |
emerygt350 |
Yes, I got the tuning kit, and well worth it. Chris has given me very good instructions to get it in a good place without the O2 sensor. I was pretty scared at first but I think tuning it is within the range of mere mortals. It really has taken many of the rough spots out. Just need to get it perfect, but at least I feel it is possible with the tuning kit from tangerine.
Lo-Fi Version | Time is now: 29th June 2024 - 01:17 AM |
