emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,211 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability.
I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw |
jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
Yes, that terminology and process is exactly what I'm working with using Chris's tuning kit.
And thanks for the input on your impedance readings - reassuring to know I'm not alone. From what I read coil failures are rare and probably very rare while the resistance is still good. So what are the chances that both of us have exactly the same failure mode? Slim I hope. Maybe an LCR guru can chime in but in the very sketchy instructions that came with my meter it says this: .....when measuring the inductance or capacitance containing a component of resistance it may get the wrong readings. And even more curiously: .. This instrument can not be used to measure the quality of the ICP, the measuring inductance is varied when there is different impedance, you may get the wrong value if you are measuring inductance of the resistance??? Maybe there's a reason why pbanders specified a professional grade LHR? Good luck with the continued tuning. Would be interested to hear if you need to make any big changes after the dyno test. Ron |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,002 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Maybe there's a reason why pbanders specified a professional grade LHR? People have reported different inductance readings from different meters. After getting the exact same model that Anders used, while I learned some things in using it, it really only got me into the ballpark. Once the car is running, beyond judging by how the car idles and drives, the only real way to dial it in is by accurately reading the AFR for the various conditions. Money would be better spent on that then an inductance meter. |
Lo-Fi Version | Time is now: 29th June 2024 - 01:49 AM |
