jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
Troubleshooting lack of interior light when doors are opened. Turns out the solid brown wires at both switches are not, in fact, connected to ground. I can splice and make a new ground connection but want to find out what's wrong and make sure there are no other grounding issues I don't know about.
Before I start pulling things out from under the dash could someone tell me where, in general to start looking? The switch wiring harness sections are difficult to trace. Thanks, Ron ![]() |
Arno914 |
Member ![]() ![]() Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany ![]() ![]() |
I repaired my buzzer lately and therefore checked the connections on the 4 pole door switches. For better understanding check with an ohm meter how the switches work. No ground via screw on the 4 pole switches! Either side (2 poles left/2 poles right) gives contact when the door opens and connects brown with brown (interior light) and red with red (buzzer on the fuse panel). Careful, one red wire has permanent 12V, so do not ground it. I additionally put shrinking tube over the red (+) connectors. Ground for the buzzer is applied via contact in the ignition switch when the key is in.
Lo-Fi Version | Time is now: 26th June 2024 - 08:23 AM |
