> 123... and your oils on the driveway, not the crankcase., If something can go wrong...
emerygt350
post Nov 6 2021, 02:09 PM
So.... Bought a 123injection distributor from tangerineracing and installed it nice and easy. Started it up to set the timing and I hear this weird slurping noise.
That nearly irreplaceable hose that goes from the block to the remote oil pressure sender had finally given out.
Chris is trying to find the appropriate fittings to replace it.
Also, chasing a vacuum leak around the intake on cylinder 4. Just replaced the spacer a month ago and really was careful with the blue gas safe sealer etc. The injector seals are all new. Spraying very carefully it really does appear to be the area near the spacer. Any tips and tricks?
Nobody would ever suspect a 914 is behind that door...
ChrisFoley
post Nov 8 2021, 09:55 AM
I am Tangerine Racing
stainless adapter
brass adapter
emerygt350   123... and your oils on the driveway, not the crankcase.   Nov 6 2021, 02:09 PM
mlindner   Yup, air cooled VW/Porsche owner lives there. All ...   Nov 7 2021, 06:44 AM
914e   Yup, air cooled VW/Porsche owner lives there. All...   Nov 7 2021, 08:29 AM
Aerostatwv   Yup, air cooled VW/Porsche owner lives there. Al...   Nov 7 2021, 12:51 PM
76-914   Look carefully at the injector to see if it is sli...   Nov 7 2021, 08:05 AM
emerygt350   Look carefully at the injector to see if it is sl...   Nov 7 2021, 10:51 AM
Van B   Emery, Can you add some photos as you work throug...   Nov 7 2021, 12:06 PM
emerygt350   Pulled the injector and added a little grease to t...   Nov 7 2021, 02:26 PM
iankarr   The OEM sender is screwed directly into the block....   Nov 7 2021, 03:35 PM
emerygt350   The OEM sender is screwed directly into the block...   Nov 7 2021, 04:18 PM
ChrisFoley   The OEM sender is screwed directly into the bloc...   Nov 8 2021, 05:22 AM
emerygt350   [quote name='emerygt350' post='2958321' date='Nov...   Nov 8 2021, 07:37 AM
ChrisFoley   I just found two different tapered metric male to ...   Nov 8 2021, 06:15 AM
BeatNavy   I was pretty sure the dual VDO sending units don...   Nov 8 2021, 06:53 AM
ChrisFoley   stainless adapter brass adapter   Nov 8 2021, 09:55 AM
emerygt350   Thanks, I was looking at that stainless one. That...   Nov 8 2021, 10:23 AM
ChrisFoley   I think the tin clears the head, even though the e...   Nov 8 2021, 03:02 PM
emerygt350   I think the tin clears the head, even though the ...   Nov 8 2021, 07:47 PM
ChrisFoley   Chris, any luck on the fitting? I assume I shou...   Nov 9 2021, 10:00 AM
emerygt350   Ok, I ordered that brass one. I will just try to ...   Nov 9 2021, 10:30 AM
ChrisFoley   I would see if I can do all the necessary tuning w...   Nov 9 2021, 10:44 AM
emerygt350   I would see if I can do all the necessary tuning ...   Nov 9 2021, 10:48 AM
emerygt350   The brass adapter doesn't thread into the bloc...   Nov 13 2021, 09:10 AM
- Lo-Fi Version Time is now: 6th January 2025 - 07:02 PM
