Rusted Heat Control Box Clean Up, Final Results Pics Added |
914Sixer |
Nov 13 2021, 04:30 PM
914 Guru Group: Members Posts: 9,032 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will need a bucket, gallon of white vinegar and quart of lemon juice. Depending on the bucket size, mix 2 parts vinegar to 1 part lemon juice. Soak part along as needed. Pull part from time to time and scrub with small tooth brush size wire brush. Keep repeating until you are satisfied clean enough to paint. Wash, dry and get ready to apply paint as flash rust will appear as soon as the part is dry. Took about 6 hrs to soak and come clean. Going to finish off with wire wheel. Before and after, you can see flash rust .
Attached image(s) |
930cabman |
Nov 13 2021, 04:35 PM
Advanced Member Group: Members Posts: 3,776 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks good as new, what will you be using for a primer?
Lo-Fi Version | Time is now: 22nd December 2024 - 11:36 AM |
