Still leaking oil after 3rd engine drop, Source? |
Wew |
Nov 22 2021, 01:34 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
I have posted several times on this forum regarding my engine and transmission rebuild. Thanks to Ian Karr's video on valve train geometry it really helped me visualize what exactly needed to be done in order to get everything lined up and adjusted properly. Haven't done it yea, but the engine is dropped and ready to tackle this project. My big concern is my inability to stop this oil leak which is present on both sides on the engine. I bought the extra thick cork valve cover gaskets from 914 rubber. Based on the images could anyone deduce the source of the problem and a once and for all remedy? Same with the push rod tubes. Are there any oil leak proof pushrod tubes and seals that can keep the oil leaks from sneaking back? The engine rebuild probably has 20 miles on it as due to the oil leaks and a terrible valve train geometry job done by a local volkswagen shop. These things prompted me to drop the motor and redo things. Oil pressure sensor leak resolved. Oil cooler seals are good and no leaks. The oil you see in the images, and some drips from the pushrod tubes, which could be from above and also on the heat exchangers streaks of oil coming down them from the engine. It also have noticed oil in the exhaust to muffler gaskets. Is this normal, if not what would that cause and remedy be? Thanks a bunch, I know I have a lot of questions but I would really prefer once and for all to address these issues. Thanks, Gary |
Shivers |
Nov 22 2021, 02:49 PM
Senior Member Group: Members Posts: 2,825 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I agree with SH above...I'm not familiar with this engine build. Heads look ported, so maybe a performance build. If you were out driving it like I would, there can be more oil than normal sloshed down the PR tubes and into the valve rocker area. With a higher compression, the engine can develop enough crank case pressure to bypass the valve cover gasket. I've seen some rubber gaskets
Lo-Fi Version | Time is now: 27th December 2024 - 12:38 AM |
