emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,211 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability.
I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw |
emerygt350 |
Sorry, I put mm but meant inches. I will fix that.
I am glad someone can use inductance. I found it to be of little value. Certainly my lcr is cheap but I do feel better about tuning it by Dyno and afr. |
Lo-Fi Version | Time is now: 29th June 2024 - 01:46 AM |
