> Type 4 oil pump rebuild, Comparison of OEM vs. Samba CNC pump
Superhawk996
post May 26 2019, 05:51 PM
Playing with the idea of what it will take to rebuild a type 4 pump.
The pump that came out of my 2.0L engine is trashed from pumping rust. Both the gears and the housings are seriously scored.
I figured I'd roll the dice and see what might be on Ebay. Took a gamble and bought a used pump hoping I might get some core parts that are useful.
I did end up with a good housing outer. However, the gears are pitted and it the inner housing plate either has a serious casting flaw, or some sort of galvanic corrosion that pitted it. I always struggle with this kind of thing. It really would have minimal effect on the pump and it probably worked OK for a lot of years. However, I'd just like to know that it is perfect going before going into a engine.
It looks like new inner plates are available but at a cost of $150+.
I decided that since I have a donor "scrap" pump, I have nothing to lose by experimenting with machining it.
Nogoodwithusernames
post Dec 6 2021, 01:13 PM
Another thing to keep an eye out for is the small nuts holding the housing together actually have threaded inserts from the factory (don't know if true of all years though?) that I believe act almost as lock nuts. I noticed that when doing my 1.7 rebuild for my VW and got that answer on my STF thread. (In sig) Might be another indicator of a pump being opened/worked on previously.
That CNC pump is pretty.
Superhawk996   Type 4 oil pump rebuild   May 26 2019, 05:51 PM
Mark Henry   Personally I'd use a new modified T1 pump and ...   May 26 2019, 05:59 PM
Superhawk996   Personally I'd use a new modified T1 pump and...   May 26 2019, 06:07 PM
Superhawk996   I decided to start with my original pump inner hou...   May 26 2019, 06:02 PM
North Coast Jim   I bought a new Melling pump. Made in Michigan from...   May 26 2019, 06:10 PM
Superhawk996   I bought a new Melling pump. Made in Michigan fro...   May 26 2019, 06:23 PM
Superhawk996   @North_Coast_Jim How many miles on the melling? ...   May 27 2019, 04:50 AM
North Coast Jim   @North_Coast_Jim How many miles on the melling? ...   May 27 2019, 06:01 AM
Superhawk996   So here is the cover with just a skim cut and the ...   May 26 2019, 06:19 PM
914sgofast2   There is a thread over on the Samba with a step by...   May 28 2019, 08:17 AM
Superhawk996   Ultimately I may machine up some sort of test fixt...   May 26 2019, 06:26 PM
Valy   Number 1 reason for failing oil pumps is the idle ...   May 26 2019, 09:40 PM
Superhawk996   Number 1 reason for failing oil pumps is the idle...   May 27 2019, 04:28 AM
Valy   @Superhawk996 It works well, no issues so far but...   May 27 2019, 02:12 PM
Mark Henry   T1 mod is easy if you have a lathe, you just have ...   May 28 2019, 09:33 AM
Superhawk996   Given that I'm a mechanical masochist I haven...   Aug 4 2019, 10:59 AM
914sgofast2   Try visiting The Samba.com website and go to the 4...   Aug 4 2019, 12:22 PM
Superhawk996   :agree: Been there before. https://www.thesamb...   Aug 4 2019, 01:00 PM
Archie   I've had one listed on FS/WTB for a couple of ...   Aug 4 2019, 05:17 PM
Superhawk996   Time to light up an old thread. I continue to bui...   Sep 19 2021, 10:02 AM
Superhawk996   Used T4 mystery pump. Heres a caution to anyone ...   Sep 19 2021, 10:59 AM
Superhawk996   T4 Mystery Pumps -- The plot thickens Recently bo...   Dec 6 2021, 10:51 AM
Nogoodwithusernames   Another thing to keep an eye out for is the small ...   Dec 6 2021, 01:13 PM
- Lo-Fi Version Time is now: 26th April 2025 - 08:31 PM
