jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
After months of chasing a rich condition on my '73 1.7 I decided to once again try pressurizing the system and applying soapy water. Glad I did because I found two more leaking hoses and a leaking Cold Start Valve gasket. But the worst culprit turned out to be a leak around the throttle shaft.
There are a number of threads about options for adding bushings and or seals, but am I right in thinking this would mainly impact idle mixture? If so, I'm wondering if other system adjustments, e.g. ECU knob and/or MPS could overcome the effects of this leak - at least until I find a machine shop to fix the TB. Thanks in advance for any suggestions. Ron |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Leak wont affect mixture with d-jet, just idle speed.
I think your bigger issue though is that it may wind up giving you a constantly changing idle speed in operation as the severity of the leak varies every time the throttle is closed. thankfully they made a ton of 1.7s and no one seems to want them, so you should be able to find another TB pretty easily. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
