jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
After months of chasing a rich condition on my '73 1.7 I decided to once again try pressurizing the system and applying soapy water. Glad I did because I found two more leaking hoses and a leaking Cold Start Valve gasket. But the worst culprit turned out to be a leak around the throttle shaft.
There are a number of threads about options for adding bushings and or seals, but am I right in thinking this would mainly impact idle mixture? If so, I'm wondering if other system adjustments, e.g. ECU knob and/or MPS could overcome the effects of this leak - at least until I find a machine shop to fix the TB. Thanks in advance for any suggestions. Ron |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
It’s unmeasured air.
I agree that you could turn the idle mixture screw (unmeasured air) in all the way and close that hole off if the bushing leaks are large enough. Depending upon how deep down this rabbit hole you would like to go….the 1.7 typically run rich. To lean it out, and get it perfect for your engine/elevation combination, here is what I do. Buy a potentiometer (a volume control switch) Buy an 02 sensor, with gauge Buy about 15 feet of double wire. Stick 02 sensor into tailpipe clamped to a coat hanger. Run wires from 02 up and over car into window, hook up to gauge. Wire up the potentiometer inline between the CHT and the ECU I now put this in the car also, so more long wires taped to car, in window This is all temporary for tuning and cheaper than a dyno tune Go drive car When WARM, start adding resistance to the CHT circuit by very slowly turning up the volume knob Add resistance until A/F mixture goes down to your desired number Last test, at this new setting, drive on highway for 15 min at high revs constant Make sure it’s not too lean Take ohm meter, measure across the potentiometer Install a resistor inline to match the potentiometer setting Enjoy life Rich |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
D-jet does not measure air. It measures manifold vacuum and temperature. The theory is that under load the vacuum drops, so the lower the vacuum the higher the load, so D-jet adds more fuel. So vacuum leaks in D-jet cause a rich mixture. Jim |
Lo-Fi Version | Time is now: 25th June 2024 - 10:17 PM |
