jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
After months of chasing a rich condition on my '73 1.7 I decided to once again try pressurizing the system and applying soapy water. Glad I did because I found two more leaking hoses and a leaking Cold Start Valve gasket. But the worst culprit turned out to be a leak around the throttle shaft.
There are a number of threads about options for adding bushings and or seals, but am I right in thinking this would mainly impact idle mixture? If so, I'm wondering if other system adjustments, e.g. ECU knob and/or MPS could overcome the effects of this leak - at least until I find a machine shop to fix the TB. Thanks in advance for any suggestions. Ron |
jrmdir |
Thanks to everyone for the great input.
I had a DOH! moment soon after I posted that when I realized what I already knew, that - as has been pointed out - any extra fuel added by the MPS due to vacuum leaks would only raise the RPMs - just like multiple tiny extra throttle openings - not lower the A/F ratio. I think I was so excited to find the previously unknown leaks that my brain just wanted it to be true that this was going to help fix the rich condition (IMG:style_emoticons/default/smile.gif) But it will indeed help to take these variables out of the picture so I can hopefully improve the idle situation and keep working on other things that do impact mixture like MPS calibration and CHTS replacement. Thanks again! Ron |
Lo-Fi Version | Time is now: 25th June 2024 - 10:31 PM |
