> Battery Tender
rmital
post Dec 16 2021, 08:41 AM
Northeast optimist
I do try to drive my 914 all year, but it will have some down time when snow and salt are an issue.
"Finally" getting a battery tender.
question:
when hooking up the charger, is it safer or good practice to disconnect the ground?
I have a switch, so easy enough to do.....
Rufus
post Dec 16 2021, 10:25 PM
QUOTE(Steve @ Dec 16 2021, 10:10 AM) *
When I had an optima battery, I had to trickle charge it or it would be dead if the car sat for a week. I hard wired the cigarette lighter with a fuse to the battery. This made it easy to plug the trickle charger into the cigarette lighter. Since switching to an AGM battery, i no longer need the trickle charge. But recently I bought another 914 with an optima battery. This one has the battery in the front trunk, so I just wired the included plug to the battery.
@Steve
Optimas are AGM batteries, no? Or am I confused?
Mark Henry
post Dec 17 2021, 08:00 AM
that's what I do!
QUOTE(Rufus @ Dec 16 2021, 11:25 PM) *
@Steve
You're correct, I saw this as well, an Optima is an AGM battery.
More likely the battery was on it's last legs and a small drain (like a clock radio) and the new battery fixed the issue.
rmital   Battery Tender   Dec 16 2021, 08:41 AM
SA-914   I have several vehicles with permanent tender plug...   Dec 16 2021, 08:49 AM
Mark Henry   Odyssey recommends that you do not charge the batt...   Dec 16 2021, 08:57 AM
oakdalecurtis   i use an Optima Red, got about 8 years out of my l...   Dec 16 2021, 10:47 AM
Root_Werks   Hard wired tenders to everything that might sit fo...   Dec 16 2021, 10:55 AM
Steve   When I had an optima battery, I had to trickle cha...   Dec 16 2021, 11:10 AM
sb914   When I had an optima battery, I had to trickle ch...   Dec 17 2021, 09:58 AM
Pezz   When I had an optima battery, I had to trickle c...   Dec 17 2021, 10:08 AM
StarBear   I disconnect the ground with a marine quick discon...   Dec 16 2021, 12:06 PM
Rufus   When I had an optima battery, I had to trickle ch...   Dec 16 2021, 10:25 PM
Mark Henry   When I had an optima battery, I had to trickle c...   Dec 17 2021, 08:00 AM
Steve   [quote name='Rufus' post='2967536' date='Dec 16 2...   Dec 17 2021, 09:09 AM
jvmarino   I have multiple hobby cars, and now have a tender ...   Dec 17 2021, 08:44 AM
Rick986   Prior to my 914, I always took the battery out of ...   Dec 17 2021, 09:32 AM
jvmarino   Prior to my 914, I always took the battery out of...   Dec 17 2021, 09:55 AM
ClayPerrine   I have the exact same model optima battery in all ...   Dec 17 2021, 11:17 AM
Mark Henry   Last winter I never charged my 680 battery for 5 m...   Dec 17 2021, 01:22 PM
Root_Werks   Last winter I never charged my 680 battery for 5 ...   Dec 17 2021, 03:53 PM
Mark Henry   Last winter I never charged my 680 battery for 5...   Dec 17 2021, 04:19 PM
Root_Werks   [quote name='Root_Werks' post='2967693' date='Dec...   Dec 17 2021, 05:13 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th November 2024 - 09:37 AM
