> To carburate OR to not carburate
sixaddict
post Dec 26 2021, 03:03 PM
Restoring a 70 which will have a 76 2 liter. Currently has factory injection but guy who will be building engine for me is anti injection. I know this becomes personal decision but could use some input on pro/cons. Cost is a concern but so is practicality and performance.
Words of wisdom please.
Merry and Happy to all!
930cabman
post Dec 29 2021, 02:14 PM
How much can we figure for a new programable FI system?
thanks
Superhawk996
post Dec 29 2021, 02:37 PM
QUOTE(930cabman @ Dec 29 2021, 03:14 PM) *
thanks
@930cabman
In kit form, DubShop used to have a nice dual ITB Megasquirt kit with wiring, all sensors, pump, etc., for about $3500. Currently showing Waiting on Throttle bodies and no pricing.
Get ready for price hike with devaluation of the dollar and supply chain issues!
It is the kit I'd love to do if I were going to stay /4 forever.
Mark Henry
post Dec 30 2021, 07:04 AM
that's what I do!
QUOTE(Superhawk996 @ Dec 29 2021, 03:37 PM) *
thanks
@930cabman
Fuel only SDS, using stock intake (stock pump, injectors, etc) and a DIY install can be done for $1072.* plus a wideband meter.
*Parts also needed (extra) MAP sensor 1 bar $73, TPS $93 (can be had at scrapyard), fuel pump relay $30 (optional but recommended).
This is the minimum extra parts needed, there's other options.
No dyno time required. Basic install time required for me is one weekend, for an amateur maybe 2-4 weekends. Tuning time for me on county back roads one hour, again for the amateur 2-4 times that number. Engine will fire up right away, with the included rich/lean knob I have no worries breaking in a new engine on SDS as you can adjust AFR on the fly.
Based on an engine with no mechanical issues. System can tolerate mild carb cam grinds, limited to the stock intake. Don't expect any more than stock performance on a stock engine, FI doesn't add HP.
NOTE crankfire "F" systems and crankfire E/MSD systems take much longer, as you have to remove the engine and fab a trigger mount.
I've done several of these /4 "D" systems on stock engines, they run great. I have SDS with crankfire on my 2.6L VW bug (T4 conversion) and I have a twin plug system I will install on my 3.0/6 conversion someday.
sdsefi.com
JamesM
post Dec 31 2021, 02:53 PM
QUOTE(Mark Henry @ Dec 30 2021, 06:04 AM) *
thanks
@930cabman
sdsefi.com
If you have the d-jet intake I would say $1000 is roughly the comfortable low end to do it yourself. It can be done for much less but with much greater time and effort, $1000 is the comfortable point for DIY. I did receive a notice that there are going to be price increases on Megasquirt hardware in the new year though, so that may change a bit.
Marios (dubshop) kit at $3500 includes $1000+ of ITBs and related hardware (and markup) that you can get by without if you already have the 2.0 intake and unless the motor is built up significantly over stock there is not any advantage to running ITBs. that being said it is a complete kit so if you are starting with nothing it may be the easy way to go. His harness is not specific to 914s though, at least not the last one i saw. Also the dubshops type 4 crank sensor, while still my personal favorite serup, does require dropping the engine to install in a 914.
Not sure if PMB is selling any systems for end user installation yet (or what they cost), but they have built out a few now that are 914 specific and use a trigger setup that replaces the distributor so you don't need to drop the engine.
sixaddict   To carburate OR to not carburate   Dec 26 2021, 03:03 PM
Root_Werks   Move to carbs will devalue your 914. If your mech...   Dec 26 2021, 03:08 PM
--axel--   I'm with Root. Don't change to carbs woul...   Dec 26 2021, 03:11 PM
914Mels   Unless you're building a race motor, I'd k...   Dec 26 2021, 03:11 PM
mlindner   I'd say they're all correct about FI. BUT ...   Dec 26 2021, 03:24 PM
Sycolyst   Current motor (2056) is dual carb (Webber IDF 40...   Dec 26 2021, 03:28 PM
lesorubcheek   Our 914 had dual Webers when we got it back in 198...   Dec 26 2021, 03:37 PM
914Sixer   I am FI guy,now that said ,run the 76 injection. ...   Dec 26 2021, 05:30 PM
930cabman   I am presently building a 2056 with an Elgin cam (...   Dec 26 2021, 06:04 PM
Ansbacher   Pros for FI: Retains originality and value. Turnk...   Dec 26 2021, 06:24 PM
930cabman   Pros for FI: Retains originality and value. Turn...   Dec 26 2021, 06:48 PM
Steve   Pros for FI: Retains originality and value. Turn...   Dec 27 2021, 12:28 PM
nivekdodge   one thing that will tell you about FI. People will...   Dec 26 2021, 07:42 PM
930cabman   one thing that will tell you about FI. People wil...   Dec 28 2021, 12:52 PM
bkrantz   What do you and/or your mechanic want to spend tim...   Dec 26 2021, 10:18 PM
rjames   If keeping the stock displacement, get a mechanic ...   Dec 26 2021, 10:23 PM
914_teener   :agree:   Dec 27 2021, 11:00 AM
Mikey914   Does your mechanic want to crack the case to put a...   Dec 27 2021, 01:06 PM
sb914   Injection is nice. But I’d rather be blown. Sor...   Dec 27 2021, 03:46 PM
sixaddict   Great help......and as expected many angles to thi...   Dec 28 2021, 09:01 AM
iankarr   In addition to @ansbacher 's list and the ot...   Dec 28 2021, 12:24 PM
PCH   The lack of testing equipment is a big problem. I...   Dec 28 2021, 06:19 PM
JamesM   Restoring a 70 which will have a 76 2 liter. Curr...   Dec 28 2021, 06:42 PM
930cabman   How much can we figure for a new programable FI sy...   Dec 29 2021, 02:14 PM
Superhawk996   How much can we figure for a new programable FI s...   Dec 29 2021, 02:37 PM
Mark Henry   [quote name='930cabman' post='2970401' date='Dec ...   Dec 30 2021, 07:04 AM
JamesM   [quote name='930cabman' post='2970401' date='Dec...   Dec 31 2021, 02:53 PM
Shivers   I make no excuses for myself, I like carbs. I like...   Dec 29 2021, 03:21 PM
mate914   Did the engine builder say what camshaft he wants?...   Dec 30 2021, 08:06 AM
Type 47   My new year's resolution is to get my 914 put ...   Dec 31 2021, 12:58 PM
JamesM   My new year's resolution is to get my 914 put...   Dec 31 2021, 03:04 PM
- Lo-Fi Version Time is now: 31st October 2024 - 08:21 PM
