Front sway bar parts -, Mounting plates question |
seanpaulmc |
Jun 24 2017, 11:49 AM
Member Group: Members Posts: 373 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
1/17/2021 - resurrecting to ask new question.
Had the fuel tank out to replace the fuel line in the tunnel. From that I could see the front sway bar. Interestingly, the passenger side was connected and the driver side is not connected. In a box of parts that was with the car I found the drop link for the driver's side. It, however, is missing the cap and bolts to attach it to the bar. Does anyone know where I can get the piece to fit this part? Size of the bolts? Thank you. |
seanpaulmc |
Jan 17 2022, 08:11 PM
Old thread.
I know I should be long past this work by now, but, I'm not. I am working on some the metal repair and removed the front sway bar today while letting the Rust Bullet dry. (IMG:style_emoticons/default/welder.gif) It took the BFH to get it out. (IMG:style_emoticons/default/smash.gif) And, I'm still trying to get the bushing out of the drivers side. From the previous feedback it was said the U-bolts in the H&H design can be problematic. I can see that with the thin sheet metal. 914LTD and PMB both sell front sway bar mounts. Both configurations are substantial compared to the square u-bolts on this H&H it was said to be. The H&H uses all standard hardware. The bolt spacing for the top u-bolt is 2-1/4 inch. Can anyone provide the bolt spacing for the 914LTD version and the PMB version of the mounts? I would like to see how they compare before choosing even with the welding involved. Thanks, Sean |
Lo-Fi Version | Time is now: 28th November 2024 - 12:37 PM |
