info for beginning welders |
scotty b |
Jan 8 2005, 05:32 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) As I have been going through some old posts I have seen a fair amount of discussion on how to weld,what machine to buy etc. As a certified welder I can tell you a few things right off the bat. if you are only going to be using it for sheet metal and light steel ( up to 3/8 ) you don't need any more then a 150 amp machine. Go mig, it is the easiest, fastest and cheapest, I know tig is THE thing now, but it isn't for sheet metal due to machine cost, material cost, learning curve and if you don't know what you are doing you can warp the hell out of a panel tigging. .023 wire is all you will need, anything larger will require more amperage and will burn through. Don't mess with flux core on sheet metal, you will most likely ruin your job. My first machine was a 250 amp and came with .035 wire and I used it for panel replacement succesfully, but not without a lot of patience. When I finally broke down and bought the neccessary parts to run .023, my job time was cut almost in half because I didn't have to give the panel as much time to cool.Spot weld across the panel not around ( noth, south, east, west, repeat ) until you have enough strenth to run small stringers, then do that in a simmilar pattern. Two pieces of angle, c-clamps, a rubber malet and a body hammer make a great brake, I made several pieces, including entry steps like this before buying a brake. Always remember, if you can see 2" of rust ......there will be 5"!!! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
mattillac |
Jan 8 2005, 06:02 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
thanks scotty!! i'm looking forward to getting into welding. it's always nice to get some
tips from a pro. how about welding stainless to regular steel? any good tips? i have a stainless muffler that i'd like to put on my teener, but i need to weld on a hanger or something to secure it. |
Lo-Fi Version | Time is now: 28th September 2024 - 09:08 AM |
