Front sway bar parts -, Mounting plates question |
seanpaulmc |
Jun 24 2017, 11:49 AM
Member Group: Members Posts: 373 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
1/17/2021 - resurrecting to ask new question.
Had the fuel tank out to replace the fuel line in the tunnel. From that I could see the front sway bar. Interestingly, the passenger side was connected and the driver side is not connected. In a box of parts that was with the car I found the drop link for the driver's side. It, however, is missing the cap and bolts to attach it to the bar. Does anyone know where I can get the piece to fit this part? Size of the bolts? Thank you. |
Mikey914 |
Jan 31 2022, 05:41 AM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Attached thumbnail(s) |
seanpaulmc |
Jan 31 2022, 11:24 AM
Mark, I appreciate the response. If you go back and look at my picture, I’m comparing the 914Rubber bushings on the right and the old ones are on the left. I feel like stock replacement might be slightly undersized for my application with the H&H drop links. It’s not a stock bar and was made with all US sizing (not metric). I’m having trouble finding where to buy replacements searching McMaster, Grainger, Summit, etc using the term rubber bushings. Is there a better description or a better source to search? Thanks, Sean |
Lo-Fi Version | Time is now: 28th November 2024 - 12:53 PM |
