Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Have a few threads about my engine dying, but wanted to ask this in a separate thread. Currently a 1.8L but want to do a 2056. If I buy a 2056 long block, I assume I can use all of my L-Jet. But I have questions:
1. Exhaust from my 1.8L will all fit and can stay, correct? I'm almost certain exhaust port spacing is the same on all engines for our cars. 2. I would need new upper engine tins since the spark plug location is different. Or do I plug and redrilll the 1.8L tins? 3. Do the rest of the tins from the 1.8L work? 4. If I use 2.0L upper tins, did they have a stanchion to attach a fuel pressure regulator? 5. I thought 1.8L FI runners have four bolts where they meet the head and 2.0L have three. Do I just drill the 1.8L runners for the third bolt (is there even room for that)? 6. Are the lengths and positions of the L-Jet runners even compatible with the 2.0L? Anything else I'm missing? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Go find the crank and rods from a 2.0 VW Bus. There are lots out there.
Buy pistons and cylinders. Get your 1.8 Heads rebuilt with 2.0 Stainless valves. Find a Bus oversized throttle body. I will help you to put it together. Buy a Raby 9590 cam kit, including the pushrods, lifters and rocker spacers. The rest is just careful assembly. Clay |
Lo-Fi Version | Time is now: 29th June 2024 - 01:17 AM |
