930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,212 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
We are about to fire a new 2056 and have tried to pump oil through the system prior to igniting. I have pulled the spark plugs and hooked up an oil pressure gauge. I can crank the starter for 30 seconds or so, but nothing registering on the gauge? More cranking?
Thanks |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
What @Superhawk996 and @fixer34 said. On my 2056 it took probably 3 x 30 second tries. Assume you're using break in oil, right?
930cabman |
What @Superhawk996 and @fixer34 said. On my 2056 it took probably 3 x 30 second tries. Assume you're using break in oil, right? Straight 30 Wt, non detergent I did not pre fill the oil filter, but will pull it today and fill it. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:25 AM |
