I was bored so decided to drop the engine, Oh my!! |
BK911 |
Feb 17 2022, 11:42 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
So many oil leaks.
Even had oil mist out the windshield defrost vent! What causes so much oil around the cylinder/case interface? Pretty wet on both sides. Side where I attached the oil breather to air cleaner has built up oil on back side of intake valves!! Have to figure out a better way for head and case vent. On a positive note, 6 8 6 6 % leakdown!! |
Shivers |
Feb 17 2022, 01:24 PM
Senior Member Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I do not know the science behind it, may be the aluminum heads and case mating cast iron cylinders with steel studs, but the head studs need to be re torqued now and then. Bugs had this problem, and it was easy to hear when the head studs had come loose. For breathing I have all three (two heads and the case breathers) running to something like this. https://www.jbugs.com/product/8544.html?utm...mRoCpqkQAvD_BwE |
Lo-Fi Version | Time is now: 26th June 2024 - 08:12 AM |
