> CV Joint Questions, All have different markings / 2 are definitely bad
Chaznaster
post Feb 20 2022, 06:52 PM
Hi All. I just tore down my axles to repack my CVs and replace damaged boots. I guess it's not surprising that they had a mix of gasket/ no gasket and Schnoor/ no Schnoor washers. That is a theme with this car!
I found few interesting things that I would like to understand better before I go looking for replacements. I am mostly interested in making sure that the ones I would like to keep (Left Inner and Left Outer) are the right parts, especially the yellow zinc one. And confirmation that the Right Inner and Right Outer are fit for retirement. I have limited experience with 914 or worn CVs ... and really appreciate your help.
Left Inner: This one has a bit of dimpling in the races but not terrible. It has the standard inner carrier (is that what they are called?) with the shoulder on one side. The outer surface has 7 153 100 199 004 LOBRO 41/84 stamped on it. I will likely reuse this one.
Left Outer: This one is in fine shape but it is an entirely different color (looks yellow zinc plated). There is NO shoulder on the inner carrier on either side. The outer surface has the VW symbol above the number 2. It looks the same in all other respects. Are there any concerns that this might be made for a different car axle?
Right Inner: the outer surface has LOBRO (in a circle) and 40-76. This one is pretty bad.
Right Outer: the outer surface has only 44-74 stamped on it. I am pretty sure it is shot as well.
iankarr
post Feb 21 2022, 09:50 PM
By “flip” I meant use the outer cv as an inner or vice-versa. Wear pattern will be different. And roll pins will be right side out:)
Chaznaster
post Feb 22 2022, 06:11 PM
QUOTE(iankarr @ Feb 21 2022, 10:50 PM) *
Great - Thanks Ian!
Chaznaster   CV Joint Questions   Feb 20 2022, 06:52 PM
914Mels   How many miles a year do you put on the car? Are t...   Feb 20 2022, 07:29 PM
930cabman   The races look somewhat worn, I would try to find ...   Feb 21 2022, 05:56 AM
volksaddict   What's up with the gasket ones? Mine have part...   Feb 21 2022, 12:39 PM
Robarabian   Yes the gaskets are available and yes you need the...   Feb 21 2022, 03:02 PM
Chaznaster   @914Mels The car is defiantly a fair weather driv...   Feb 21 2022, 05:31 PM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 21 2022, 06:16 PM
Chaznaster   [b]@[url=http://www.914world.com/bbs2/index.php?...   Feb 21 2022, 06:45 PM
914Mels   Unless you have a limited slip differential, your ...   Feb 21 2022, 06:05 PM
Chaznaster   Unless you have a limited slip differential, your...   Feb 21 2022, 06:36 PM
iankarr   By “flip” I meant use the outer cv as an inner...   Feb 21 2022, 09:50 PM
930cabman   By “flip” I meant use the outer cv as an inne...   Feb 22 2022, 05:59 AM
Chaznaster   By “flip” I meant use the outer cv as an inne...   Feb 22 2022, 06:11 PM
volksaddict   Good info here! Thanks robarabian for the gask...   Feb 22 2022, 08:35 PM
Chaznaster   UPDATE … Hello. I recently got my trailing arm ...   Mar 25 2022, 07:09 PM
914Mels   gaskets only on the ones with the groove for them....   Mar 25 2022, 07:30 PM
Chaznaster   Thank you!   Mar 26 2022, 06:11 AM
Chaznaster   Just closing out thus thread. I ended up getting ...   Jun 3 2022, 07:02 PM
malcolm2   you might ask Tangerine Racing. I bought some fro...   Jun 5 2022, 10:02 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 16th December 2024 - 12:50 AM
