Saturday, 5 April 2025
> Another 914-6 GT Tribute Project
Tom1394racing
post Feb 14 2022, 01:04 PM
After having enjoyed several 911’s over the past 40 years, I decided about a year ago that my next project would be a 914-6 GT Tribute car. I had been thinking for some time about a mid-engine open car but the Boxster is just not my cup of tea. I am more of a 70’s air cooled hot rod type and I love my ’73 Signal Orange 911 RSR tribute car. So a 914-6 GT seemed like an obvious choice. It ticked all my boxes and I have always admired the ‘70’s GT race cars.
My friends at Auto Associates in Canton, CT knew I was considering a 914-6 GT project so when a customer’s ’73 914 2.0 became available there last fall we put it up on their lift, took a close look and deemed it an acceptable starting point. The project plan is to follow the same process I have used on my RSR and my ‘70E restoration projects. I strip the car in my home shop, send the shell to Auto Associates for the metal work, chassis stiffening and paint. The painted shell comes back to me and I do the mechanical work and reassembly.
My plan is not to do a 100% accurate GT tribute but rather to build a car that looks, sounds and drives like a street friendly GT. I am not planning on any serious track or autocross but more of a fun spirited street hot rod. I know there is a ton of expertise and experience on this forum so I will be looking for some sage advice as I document the build in this thread. So here are my thoughts:
Exterior
GT flares front and rear. I will likely leave the decision of metal vs FG to Auto Associates. I would like the car to be as light as is practical. I have FG flares on my RSR and they have held up very well over the 15 years since the original restoration. I am also planning to do the lightweight, balsa reinforced front and rear trunk lids. I also would like to do the GT style double grill engine cover. Not sure if anyone makes these or if I will have Auto Associates fabricate one from my existing cover. I will go with the hood pins front and bungees rear for lid closure. Not sure whether to go with the motor operated headlights or if the cable operated system is reliable enough. I do not plan to do a lot of night driving. For wheels, I am thinking Minilites on the rear and Fuchs on the front. I also want to keep the removable top as open air driving is one of my key objectives. I am liking Mexico Blue for the color.
Interior
I plan to go with a 911 steering column and LHS 911 ignition switch as well as 911 turn signal, wiper switches and clamshell. I am also thinking of a reproduction 911 style hockey puck steering wheel. Door panels would be the GT style with strap operated pulls for door opening. I am also thinking of a pair of GTS Classic vintage seats perhaps the LeMans series. Gauges will mimic the GT type.
Drivetrain
I have a 3.0 L SC long block that I plan to use as a basis for power. I am thinking 9.5 CR with ModS type cams and a twin plug distributor. I am also toying with the idea of EFI. I am thinking 200-225 HP. I will stick with the 901 gearbox and the special 215 mm 9 bolt flywheel. I would use 911 output stubs, Sway Away free floating axles, and 911 stubs axles & hubs. I will use a front cooler and oil plumbing similar to the GT. Not sure which option to take with regard to the motor mounts.
Suspension
Other than 911 3.5” caliper spaced front struts, and 911 front hubs, I have not given the suspension much thought as yet. I do not want the car to be so stiff and jarring that it knocks my fillings out on the pothole strewn roads here in CT. That said, I also do not want the car to roll and lean like my stock ‘70E. I like the stock type of front and rear roll bars, maybe a little bigger than the stock size. I am thinking early 911S Aluminum calipers in the front. No sure about the rear calipers. I like the 15” Michelin TB’s for tires.
Chassis Stiffening
Like all 914’s this one is not rust free. After the rust repairs, I am planning to have Auto Associates install the chassis stiffening kits for the front torsion bar area, sills and rear suspension including the rear trailing arms. I am also planning on a weld-in roll bar with diagonals tied into the door sills that will allow for reasonably easy entry and exit. I want the chassis to be as stiff as possible yet still allow for the removable Targa roof.
Well…That is the current plan. I am very interested in suggestions and input from those of you who have been down this road before me. I plan to post progress with photos as I go forward and I look forward to all your comments.Attached Image
post Feb 22 2022, 08:58 PM
Resident German
QUOTE(Tom1394racing @ Feb 14 2022, 11:04 AM) *
That 916 front bumper does not look like any of the crappy aftermarket ones you usually see.
I'm intrigued ...
Tom1394racing   Another 914-6 GT Tribute Project   Feb 14 2022, 01:04 PM
BadToTheBown   Some of us will be watching, think I want to do th...   Feb 15 2022, 02:16 PM
mlindner   I was thinking of the exact same thing....forgot, ...   Feb 16 2022, 01:57 PM
Tom1394racing   I was thinking of the exact same thing....forgot,...   Feb 16 2022, 04:43 PM
BadToTheBown   [quote name='Tom1...That's a beauty...[/qu...   Feb 16 2022, 10:25 PM
infraredcalvin   Where did you get the double grill engine cover?...   Feb 17 2022, 08:58 PM
mlindner   Tom, a lot of people will want to see this build. ...   Feb 16 2022, 02:20 PM
Tom1394racing   Tom, a lot of people will want to see this build....   Feb 16 2022, 04:22 PM
mlindner   Sir Andy, can you change this to 914World Garage. ...   Feb 16 2022, 04:28 PM
Tom1394racing   Sir Andy, can you change this to 914World Garage....   Feb 22 2022, 11:06 AM
Tom1394racing   Admin Edit: Duplicate post removed.   Feb 22 2022, 11:04 AM
ClayPerrine   Please consider a stiffener kit for the longitudin...   Feb 22 2022, 11:30 AM
Tom1394racing   Please consider a stiffener kit for the longitudi...   Feb 22 2022, 07:08 PM
Cairo94507   Sounds like a nice build. Like Clay said, I think...   Feb 22 2022, 02:43 PM
Tom1394racing   Sounds like a nice build. Like Clay said, I thin...   Feb 22 2022, 07:12 PM
mb911   Let me know if I can help. I make a good amount if...   Feb 22 2022, 02:59 PM
Tom1394racing   Let me know if I can help. I make a good amount i...   Feb 22 2022, 07:10 PM
mb911   Let me know if I can help. I make a good amount ...   Feb 23 2022, 01:59 PM
jim dorociak   I currently have the front 911 hubs/ new SC brake ...   Feb 22 2022, 03:48 PM
SirAndy   Well…That is the current plan. That 916 front bu...   Feb 22 2022, 08:58 PM
Luke M   Well…That is the current plan. That 916 front b...   Feb 23 2022, 08:56 AM
TRS63   Sounds like a great plan, looking forward to follo...   Feb 23 2022, 07:06 AM
rgalla9146   Hey Tom, You have like-minded company close b...   Feb 23 2022, 08:29 AM
Cairo94507   @Tom1394racing - Hi Tom, Original steering wheel,...   Feb 23 2022, 10:37 AM
mb911   http://www.914world.com/bbs2/index.php?sho...=2696...   Feb 23 2022, 02:02 PM
Tom1394racing   http://www.914world.com/bbs2/index.php?sho...=269...   Feb 23 2022, 06:47 PM
Tom1394racing   Updating his thread.... I had to put the car in t...   Feb 24 2022, 10:16 AM
Tom1394racing   Over the past month, I have slowly been stripping ...   Feb 24 2022, 11:54 AM
Tom1394racing   More rust I think I have gone about as far as ...   Feb 24 2022, 01:27 PM
ChrisFoley   No surprises there. The CA car on my lift is worse...   Feb 24 2022, 03:37 PM
IronHillRestorations   Let me know if I can offer any advice Tom. You’v...   Mar 4 2022, 07:56 PM
Tom1394racing   Let me know if I can offer any advice Tom. You’...   Mar 7 2022, 09:51 AM
Lucky9146   Tom Happy to help in any way possible. I was for...   Mar 7 2022, 10:32 AM
Tom1394racing   I have been able to source some cool parts for thi...   Apr 2 2022, 08:59 AM
BadToTheBown   Unused pair of Ben's heat exchangers Really ...   Apr 2 2022, 11:17 AM
mb911   Tom working on tanks now let me know when your rea...   Apr 2 2022, 12:56 PM
Tom1394racing   Look what showed up today from the UK.   Apr 6 2022, 02:49 PM
ibmiked   For anyone who doesn’t know, Tom is an invaluabl...   Apr 6 2022, 07:58 PM
Tom1394racing   For anyone who doesn’t know, Tom is an invaluab...   Apr 12 2022, 06:58 AM
jjeffries   Hi Tom, here’s my first post on 914World … I�...   Apr 10 2022, 07:48 PM
brant   I still think a roll bar in a street legal car is ...   Apr 12 2022, 07:42 AM
mepstein   I still think a roll bar in a street legal car is...   Apr 12 2022, 09:35 AM
blabla914   Tom, Excited to see how this build turns out. If...   Apr 12 2022, 12:43 PM
ibmiked   Agreed, a roll bar is dangerous without a helmet. ...   Apr 13 2022, 08:01 PM
mepstein   Agreed, a roll bar is dangerous without a helmet....   Apr 13 2022, 08:33 PM
ibmiked   Agreed, a roll bar is dangerous without a helmet...   Apr 14 2022, 07:19 PM
brant   Why ride a motorcycle? Or a bicycle on a public...   Apr 15 2022, 06:43 AM
ClayPerrine   Why ride a motorcycle? Or a bicycle on a publi...   Apr 15 2022, 09:23 AM
lesorubcheek   You are less likely to be hurt in an accident whe...   Apr 16 2022, 10:48 AM
wonkipop   Why ride a motorcycle? Or a bicycle on a publ...   Nov 1 2022, 07:51 PM
davehg   I modded my roll bar in a similar fashion to the a...   Apr 14 2022, 10:02 PM
ibmiked   Getting on a motorcycle or bicycle, even with a he...   Apr 16 2022, 04:16 AM
VegasRacer   A car with a roll bar is indeed dangerous. Several...   Apr 16 2022, 10:34 AM
bahnzai   Hey guys, you know we are kinda walking all over t...   Apr 16 2022, 11:20 AM
Tom1394racing   Time for an update on my GT project. After a long ...   Nov 1 2022, 12:14 PM
Lg914   [quote name='Tom1394racing' post='3038...   Nov 29 2022, 05:58 PM
-JR-   Time for an update on my GT project. After a long...   Jan 11 2023, 04:27 PM
Alain V.   [quote name='Tom1394racing' post='3038974' date='...   Jan 11 2023, 07:07 PM
Cairo94507   As long as that trip will be, it will be well wort...   Nov 1 2022, 12:38 PM
mepstein   There’s a chemical strip shop west of Harrisburg...   Nov 1 2022, 06:45 PM
mepstein   Pics so far   Nov 1 2022, 06:56 PM
Freezin 914   Tom, Like most people here, I can’t wait until n...   Nov 1 2022, 07:22 PM
Cairo94507   @mepstein - Mark, I love that you are preparing t...   Nov 2 2022, 07:10 AM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 2 2022, 08:43 AM
Tom1394racing   There’s a chemical strip shop west of Harrisbur...   Nov 4 2022, 08:56 AM
mepstein   Just got done e-coat   Nov 4 2022, 11:29 AM
TJB/914   Just got done e-coat M Outstanding :worship: T...   Nov 4 2022, 11:52 AM
rgalla9146   Just got done e-coat That's beautiful Mark...   Nov 4 2022, 04:26 PM
mepstein   Just got done e-coat That's beautiful Mar...   Nov 4 2022, 05:44 PM
Cairo94507   That is really cool Mark. :beer2:   Nov 4 2022, 01:22 PM
dlee6204   Just got done e-coat Mind sharing the business ...   Nov 4 2022, 05:55 PM
mepstein   Just got done e-coat Mind sharing the business...   Nov 4 2022, 06:14 PM
mb911   [quote name='dlee6204' post='3039672' date='Nov 4...   Nov 5 2022, 08:25 AM
mepstein   [quote name='dlee6204' post='3039672' date='Nov ...   Nov 5 2022, 11:23 AM
r_towle   What happened to the guy building a GT tribute 914...   Nov 6 2022, 07:16 PM
Tom1394racing   The shell has been stripped and mounted on a custo...   Nov 29 2022, 09:01 AM
Tom1394racing   Since my last posting, the external longs were ope...   Jan 11 2023, 03:25 PM
Tom1394racing   Inner longs don't look too bad and the heater ...   Jan 11 2023, 03:29 PM
TJB/914   Inner longs don't look too bad and the heater...   Jan 11 2023, 06:11 PM
mepstein   Have to wait and see what it looks like after the ...   Jan 11 2023, 06:38 PM
gereed75   JR, not sure what you are hoping to accomplish spr...   Jan 11 2023, 06:40 PM
-JR-   JR, not sure what you are hoping to accomplish sp...   Jan 11 2023, 08:33 PM
gereed75   rust 911 appears to be a chemically engineered pho...   Jan 11 2023, 07:20 PM
Tom1394racing   The chassis has now completed the dipping/E-coat p...   Jan 27 2023, 01:39 PM
mepstein   I just talked to Neil the other day. Our cars migh...   Jan 27 2023, 03:22 PM
Tom1394racing   Yes Mark...I spoke to Neil this afternoon.   Jan 27 2023, 04:03 PM
mepstein   We had to take your car off the truck to get to mi...   Feb 26 2023, 07:13 PM
Tom1394racing   Mine is back home as well. I am pretty happy with ...   Feb 28 2023, 03:40 PM
Tom1394racing   Here are some examples of the nasty hidden sins th...   Feb 28 2023, 04:02 PM
Tom1394racing   After the extensive rust repair, the GT conversion...   Feb 28 2023, 04:09 PM
mepstein   The dip and e-coat make the good metal look really...   Feb 28 2023, 04:56 PM
Tom1394racing   Update - The car was delivered to Auto Associates ...   Apr 18 2023, 12:54 PM
Tom1394racing   The rust repair has started with removal of the ru...   Apr 18 2023, 01:07 PM
Cairo94507   Oh, this is going to be fun to watch. :popcorn: ...   Apr 18 2023, 03:48 PM
Tom1394racing   So the plan for the car is as follows: Engine 3....   Apr 18 2023, 06:37 PM
mepstein   Looks like a great combo. Maybe think about M cal...   Apr 18 2023, 07:29 PM
infraredcalvin   Looks like a great combo. Maybe think about M ca...   Apr 18 2023, 08:07 PM
Tom1394racing   Looks like a great combo. Maybe think about M c...   Apr 19 2023, 06:02 AM
Cairo94507   Wow- that 3.2 combo is going to produce a very nic...   Apr 19 2023, 06:58 AM
Dion   Looks to be a formidable machine. Best of luck. Wi...   Apr 19 2023, 07:11 AM
6 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 5th April 2025 - 08:31 AM
