The '76 - doing it right this time, Finishing the interior |
76-914 |
Jan 26 2022, 10:07 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
In 2009 I bought this '76 from The LeMay Museum. It had been donated to the museum by one of their members. They in turn decided to sell it and use the proceeds towards other projects they had in their inventory. Google them and you'll see it would not have been a good fit.
Upon delivery I discovered there were areas where rust had staked it's claim. The sail panels had, as I now know, the usual rust; the battery tray and the area immediately behind it plus a small area on top of the long beneath; and finally a few spots along the front rain channel. To say I was distraught would be an understatement. Thirteen years and 2 more 914's later I know it was a good deal. Did I mention I paid $1600 for it delivered. The longs were solid as was the rest of the car. I removed the wiring mess for the car alarm & CB radio then reconnected all the wires to their original terminals. Next I replaced the Fuel Pump relay, added gas. After a turn of the key it coughed, farted and started. That's pretty much the Reader's Digest version but little more was done than that. I hadn't worked on any cars since I was a teen and none of those needed rust repair. However, after building an airplane years earlier, I had some experience with aluminum and fiberglass. Do you see where this is going? I thought it time that I go back and do a proper repair job on the old girl. Don't get me wrong. I thought that the aluminum angle patch pieces on the rain channel, the fiberglass in the Hell Hole and Bondo on the sail panels was "good enough"! Looking back, I didn't know Shit from Apple Butter. It has remained as such but Since both of my Subaru conversions are basically finished, sans a paint job on the '73, I decided to go back and correct my "Get're done" repairs. I bought the rail repair pieces from 914rubber which in turn gave me an excuse to buy a metal shrinker/stretcher. Bore yourself if you will, as there are more interesting and detailed metal restorations going on here, but I thought I'd better post these improvements for the next owner. 1 of 4 2 of 4 and I just noticed I need to resize my camera so bear with me. The next update will have more pics per post. |
Root_Werks |
Feb 24 2022, 01:53 PM
Village Idiot Group: Members Posts: 8,484 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
You never really know what you have until you start removing paint. My 75 had a front end repair that was so-so. Shop that's painting it did better work to correct a few things.
Looking good! |
76-914 |
Feb 27 2022, 08:55 PM
You never really know what you have until you start removing paint. My 75 had a front end repair that was so-so. Shop that's painting it did better work to correct a few things. Looking good! I guess you have to expect it with a 50 yo car, eh? Whoever replaced the right front fender did a good job. But the guy that did the left qtr panel; not so much. Sanding is 85% done. I need to do the frunk lid, windshield frame, door jambs and those hard to access areas. The windshield is just sitting there since it's safer than sitting on the floor. This little rear panel took lots of different attachments to get it down to metal After removing the the bondo on the qtr panel you can see holes from when they used the screw type slide hammer. They didn't pull it out much though. They must have had bondo on sale that week. (IMG:style_emoticons/default/shades.gif) Before I could weld those closed I need to remove the undercoating and clean up that inner fender. Some more pic's of sanded areas. Oops. I see a little bondo spot I left on the right front fender. (IMG:style_emoticons/default/unsure.gif) Looks like a Porcupine with the all the studs. Many more were added and sanded down as it progressed. You can't do them all at once or it's a PITA getting the slide hammer attached. That and it would be like reaching into a Cactus patch. You can better see the holes that needed to be welded up in this pic. A few more: Some almost finished profile pics. I'll hit it with the DA once more then a skim coat. Attached image(s) |
Lo-Fi Version | Time is now: 24th November 2024 - 10:32 PM |
