Anyone used off-the-shelf exhaust studs in a pinch? |
jrmdir |
Mar 3 2022, 08:19 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hi:
I'm swapping out the HE's on my 1.7 and found that, incredibly, a DAPO installed them with no copper gaskets! So I ordered some and am now ready to go. Except I didn't think to order new studs and nuts. This not a permanent project as I expect to refresh the engine later this year - I just want to get it back on the road this weekend. In that case, I'm considering either re-using the old studs (which all came out due to rusted nuts) or trying these Dorman parts. I may need to shorten them but they appear to be the correct thread size. Is there anything I'm not thinking of if I use these? https://www.autozone.com/emission-control-a...mp;gclsrc=aw.ds Thanks, Ron |
VaccaRabite |
Mar 3 2022, 09:01 AM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As long as the stockers are okay, there is no good reason not to reuse them.
But if the rusted on nuts eroded the studs, the autozone studs should be fine. As long as the studs are out of the head, inspect the hell out of the head to make sure the bores and internal threading are good. I always worry about those when the studs come out. And if you need to size up to step studs, this would be the time to find out - not when you are putting everything back together. Zach |
Lo-Fi Version | Time is now: 26th June 2024 - 09:56 AM |
