914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I am rebuilding my rear brakes. I've taken everything apart, cleaned them with Simple Green and am currently soaking the parts in Evaporust. However, I might need to sandblast them.
1. Anything I should know before I proceed? 2. What to plug/tape up? I'm assuming all holes and machined surfaces? 3. What about the area in the caliper where the piston goes? 4. What blasting media should I use? I have some dull aluminum oxide I've used several times. I've looked on the 'Net and found a few tidbits, but nothing specific to 914 brake calipers, so I thought I'd post here and see if anyone had any experience, tips and advice. Thanks! |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Use glass beads not sand.
914 RZ-1 |
Use glass beads not sand. Thanks! Will do! Thanks! This was helpful, but there was only a brief mention of sandblasting. I have the PMB video bookmarked as well, so between this and that I should have what I need to rebuild these, but I'd still like to know what I need to do to properly sandblast these. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:44 PM |
