Simple Anti-Theft Switch, Wiring suggestions |
FlatSix |
Mar 14 2022, 09:42 AM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
So I want to install a switch hidden under the dash to stop the engine starting.
Having done a search, the black/purple wire going to the tachometer seemed a likely candidate to break the circuit. However, when I disconnected it from the tach, the car would still start! Which wire should I use? The engine is a 1973 2.0 four cylinder with fuel injection. |
jvmarino |
Mar 14 2022, 10:31 AM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
An easy anti-theft method is to pull the coil wire to distributor. Even if you leave the wire in the engine bay, I would expect most thieves would figure after lots of cranking and no starting, the car is just an old car and is not working, and then walk-away.
Lo-Fi Version | Time is now: 25th June 2024 - 07:45 PM |
