Simple Anti-Theft Switch, Wiring suggestions |
FlatSix |
Mar 14 2022, 09:42 AM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
So I want to install a switch hidden under the dash to stop the engine starting.
Having done a search, the black/purple wire going to the tachometer seemed a likely candidate to break the circuit. However, when I disconnected it from the tach, the car would still start! Which wire should I use? The engine is a 1973 2.0 four cylinder with fuel injection. |
mmichalik |
Mar 15 2022, 10:56 AM
MikeM Group: Members Posts: 708 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I know you wanted a simple solution but, the Bluetooth 123 distributor has a function where you can set it up so the car will not start without your phone. They call it the "immobilizer" button.
Works very well as an anti-theft device. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:14 PM |
