FlatSix |
English Member ![]() ![]() Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 ![]() |
So I want to install a switch hidden under the dash to stop the engine starting.
Having done a search, the black/purple wire going to the tachometer seemed a likely candidate to break the circuit. However, when I disconnected it from the tach, the car would still start! Which wire should I use? The engine is a 1973 2.0 four cylinder with fuel injection. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If the car is injected, then just put in a switch to cutoff the fuel pump. That way the potential thief thinks there is something wrong with the car because it starts and then dies. If you do this to a carbed car, it will run on what is in the float bowls then die.
Be careful with grounding the tach wire on a six. The CD boxes don't like you doing that. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
If the car is injected, then just put in a switch to cutoff the fuel pump. That way the potential thief thinks there is something wrong with the car because it starts and then dies. If you do this to a carbed car, it will run on what is in the float bowls then die. Be careful with grounding the tach wire on a six. The CD boxes don't like you doing that. (IMG:style_emoticons/default/agree.gif) not like the CD box is worth risking due to replacement cost,I have a nice little switch that breaks the pump power supply,its not easily seen and works good. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:12 PM |
