Degreasing a wire harness? |
Geezer914 |
Mar 15 2022, 12:12 PM
Geezer914 Group: Members Posts: 1,798 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
What is the best way to degrease a fuel injection wire harness? (IMG:style_emoticons/default/popcorn[1].gif)
JeffBowlsby |
Mar 15 2022, 12:47 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What is the best way to degrease a fuel injection wire harness? (IMG:style_emoticons/default/popcorn[1].gif) paint thinner acetone |
windforfun |
Mar 15 2022, 07:09 PM
Senior Member Group: Members Posts: 1,999 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
What is the best way to degrease a fuel injection wire harness? (IMG:style_emoticons/default/popcorn[1].gif) paint thinner acetone These solvents will melt what you're trying to clean. Try WD-40. |
JeffBowlsby |
Mar 15 2022, 10:28 PM
[quote name='windforfun' date='Mar 15 2022, 06:09 PM' post='2988496']
[quote name='JeffBowlsby' post='2988370' date='Mar 15 2022, 10:47 AM'] [quote name='Geezer914' post='2988360' date='Mar 15 2022, 11:12 AM'] What is the best way to degrease a fuel injection wire harness? (IMG:style_emoticons/default/popcorn[1].gif) [quote] paint thinner acetone [/quote] These solvents will melt what you're trying to clean. Try WD-40. [/quote] I regularly use citrus degreasers, simple green, paint thinner, acetone depedning on the situation, and have for at least 20 years to clean up harnesses. Acetone will remove the color striping and printed numbering on wire insulation so be cautious. No harness damage whatsoever. The military uses acetone for this exact purpose, but the caution is to wear latex gloves and work in a well ventilated area. The solvents work the best against grease residues, the water based degreasers less so, but all are effective with enough effort. There may be other cleaners that could be effective but I have not tried everything. Harness casing is chemical resistant and quite durable. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:18 AM |
