emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
So, was running fine, going to double check my timing, wouldn't restart (tried, but couldn't keep running). No pump sound and no pressure on the gauge (I love you, fuel pressure gauge). Whacked the pump with a screwdriver handle, nothing. Pushed it into the garage, figured I would give it one last listen in the quiet, heard a little bit of something, then a little grumble from the pump and I had pressure again. Started up just fine.
To me that says fuel pump, not relay. Any other experienced folk have some wisdom? I need to move my pump up front anyway but I was planning on keeping the original. now that I am thinking about it, it did struggle to start earlier in the day as well but cleared up. Car sat for a couple months during the winter. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Not trying to be an (IMG:style_emoticons/default/bootyshake.gif) Had you tested with a DMM for power at the fuel pump rather than (IMG:style_emoticons/default/smash.gif) with a screwdriver you would have data and facts to work with and we wouldn't be guessing. (IMG:style_emoticons/default/poke.gif)
At least you had the fuel gauge which is data about the fuel pump output (i.e. fuel pressure). (IMG:style_emoticons/default/smilie_pokal.gif) What we don't know is that the fuel pump had input (12v & free-flowing fuel at the pump inlet) |
emerygt350 |
Not trying to be an (IMG:style_emoticons/default/bootyshake.gif) Had you tested with a DMM for power at the fuel pump rather than (IMG:style_emoticons/default/smash.gif) with a screwdriver you would have data and facts to work with and we wouldn't be guessing. (IMG:style_emoticons/default/poke.gif) At least you had the fuel gauge which is data about the fuel pump output (i.e. fuel pressure). (IMG:style_emoticons/default/smilie_pokal.gif) What we don't know is that the fuel pump had input (12v & free-flowing fuel at the pump inlet) Yeah yeah yeah... that would require me to go downstairs into the basement, find the multi meter, back up into the yard, yadda yadda yadda, look up that thread on fuel pump trouble shooting, take the top off the relay board, figure out which way is the front of the car... blah blah blah. The screwdriver was there in my hand. It was made for whacking. It has fuel, it is the question of power that I will have to pursue... maybe even with your damn multimeter. |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,614 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
Not trying to be an (IMG:style_emoticons/default/bootyshake.gif) Had you tested with a DMM for power at the fuel pump rather than (IMG:style_emoticons/default/smash.gif) with a screwdriver you would have data and facts to work with and we wouldn't be guessing. (IMG:style_emoticons/default/poke.gif) At least you had the fuel gauge which is data about the fuel pump output (i.e. fuel pressure). (IMG:style_emoticons/default/smilie_pokal.gif) What we don't know is that the fuel pump had input (12v & free-flowing fuel at the pump inlet) Yeah yeah yeah... that would require me to go downstairs into the basement, find the multi meter, back up into the yard, yadda yadda yadda, look up that thread on fuel pump trouble shooting, take the top off the relay board, figure out which way is the front of the car... blah blah blah. The screwdriver was there in my hand. It was made for whacking. It has fuel, it is the question of power that I will have to pursue... maybe even with your damn multimeter. I’m not gonna lie @Superhawk996 emery makes a convincing case. As a military man, I would take it one step further and remove that pump from command due to loss of confidence in its ability to run fuel delivery operations. Leaving it there sets a bad example for the other parts on the car and the next thing you know, they’ll stop working as well! (IMG:style_emoticons/default/blink.gif) |
Superhawk996 |
I’m not gonna lie @Superhawk996 emery makes a convincing case. As a military man, I would take it one step further and remove that pump from command due to loss of confidence in its ability to run fuel delivery operations. Leaving it there sets a bad example for the other parts on the car and the next thing you know, they’ll stop working as well! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/lol-2.gif) Ya' all welcome to swap as many parts as your budget affords but the fact remains we don't know if 12V was present and/or whether fuel was flowing freely. The fuel lines under the tank are notorious for kinking and of course the in tank fine mesh fuel filters have been know to get clogged. I guess I don't know for sure but it seems we are discussing an old 3 port pump - rear mounted? Temporary vapor lock? I know I'm stretching a bit at the mesh sock being temporarily clogged but to say it wasn't is an assumption. I don't normally replace parts on assumptions that I haven't verified. If anyone makes a good case, it's Clay - buy the new pump to ease draining tanks and then if you need it, you have it and can relocate to the front. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:07 AM |
