930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,212 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
New build and have her running on a test bed/rolling cart for engine/trans installation. All seems tight with the exception of the rear main area. Short of dis assembly or slathering the cam plug and oil gallery plugs with sealant, has anyone tried pressurizing the oil system and visually looking for a leak? Everything looks ok, but she drips every 4 or 5 seconds when running.
Thanks in advance |
930cabman |
VICTORY
Yes, I had an old flywheel laying around with some heat spots, machined the center hub off and torqued it in place with a new O ring and new Elring seal. Pressurized with about 70PSI and sure enough one of the oil galley plugs was dripping. Took everything apart cleaned things and put the culprit back in. No leak |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
VICTORY Yes, I had an old flywheel laying around with some heat spots, machined the center hub off and torqued it in place with a new O ring and new Elring seal. Pressurized with about 70PSI and sure enough one of the oil galley plugs was dripping. Took everything apart cleaned things and put the culprit back in. No leak Hello @930cabman! Can you share how you pressurized the engine with 70psi? Since I have my engine out, much as well do the same. thank you! |
930cabman |
VICTORY Yes, I had an old flywheel laying around with some heat spots, machined the center hub off and torqued it in place with a new O ring and new Elring seal. Pressurized with about 70PSI and sure enough one of the oil galley plugs was dripping. Took everything apart cleaned things and put the culprit back in. No leak Hello @930cabman! Can you share how you pressurized the engine with 70psi? Since I have my engine out, much as well do the same. thank you! Yes, connected shop air into the 1/8" female pipe port for the oil pressure sender. If you are having leaking at the flywheel end you will need something to seal the flywheel hub area. I picked 70psi because when running an oil pressure gauge indicated 70psi. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:14 PM |
