TA bushings bad?, How can I tell if they're bad? |
ewdysar |
Jan 10 2005, 06:12 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
My car feels kinda like it's getting small steering inputs from the rear while freeway cruising on smooth and level stretches. I'm figuring that it's the trailing arm bushings (probably original). I guess it could also be a twitchy alignment, or just me getting used to a real sports car again.
How can I check the TA bushings for play without major disassembly? If they're bad, I'm probably going with Mueller bearings. Mueller, where are the rear bearings available? I checked them out once with a link in your signature file, but that link's gone now... Thanks, Eric |
Mueller |
Jan 10 2005, 06:48 PM
I'm out of stock right now....Tarett Engineering has some in stock
if the bushings are that bad, you should be able to jack the car up and check by grabbing the end of the t/a and shaking it.... |
Lo-Fi Version | Time is now: 24th June 2024 - 07:39 AM |
