Cordless soldering irons, wire splicing |
vitamin914 |
Mar 30 2022, 05:46 AM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
I have mostly used soldering stations (Metcal and Hakko) that have adjustable temperature controls. Great for benchwork, not so much when you are upside down under the dash.
Weller, Milwaukee, Hakko make some battery powered units and Ive seen some no name butane powered irons. None seem to have much in the way of good temperature control. Twenty years ago I had a butane micro torch / soldiering iron - didn't like it at all. The solder would oxidize in seconds (dross up) and I was forever trying to keeping it clean no matter how low I kept the flame. Put it down the wrong way and the exhaust port would burn the table. I did like the micro torch tip for shrinking heat shrink tubing but that was about it. Anyone have experiences with newer cordless soldering irons - battery or butane? |
VaccaRabite |
Mar 30 2022, 11:56 AM
En Garde! Group: Admin Posts: 13,542 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What about those splicers that are a combo of the two?
The low melt solder connectors that look like butt splicers and claim to be also watertight? (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.shopify.com-1435-1648662960.1.jpg) I've never used them before but picked some up and was planning on using them on the Westy that I'm about to replace the entire electrical system. Snake oil? Overkill? Zach |
Superhawk996 |
Mar 30 2022, 03:49 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
What about those splicers that are a combo of the two? Zach, When I was doing DoD work, I saw numerous failures with these types of low temp solder connectors. When they are done right, they work. They are tricky to do right. I've seen a lot of cold solder joints that led to intermittent issues that were ultimately traced back to one of these connectors that wasn't done properly. Personally, I won't touch them. Solder (ugh!) or crimp ( (IMG:style_emoticons/default/wub.gif) ) but avoid these like the plague. |
Lo-Fi Version | Time is now: 18th September 2024 - 06:58 PM |
