jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hi guys. I am moving pretty good on all my rust and bodywork issues--need some info and suggestions.
1.-What is the glue of choice? i.e.: Hysol products, or the regular epoxy stuff? 2. How are ya'll installing these? trimming,,etc....do you grind down and feather edge the edges as installed, or build up glass beyond the bond seam and feather edge that?? I was test fitting mine yesterday, and my left side ones are trimmed along the edges about 1&1/2 inch less of a diameter than my right side ones--I called AA about them and the guy suggested I vacuum bag them and add more material?????? Not the answer I was hoping for--so in the interest of this project moving ahead --I am going to make them work. But as I see it now, the right and left side are going to be different from each other, but thankfully, the same on the whole side respectively. Thanks in advance!!! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,296 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
You MUST check the alinement from side to side to get them the same. Check that they are centered on the wheel well and the same distance off of the bottom edge. Clamp them on and mark them.
Ask me how I know? Paul |
Lo-Fi Version | Time is now: 25th June 2024 - 07:44 PM |
