BadToTheBown |
Newbie ![]() Group: Members Posts: 36 Joined: 12-July 20 From: ABQ NM Member No.: 24,488 Region Association: None ![]() ![]() |
Looks like I might need to pull me engine (Porsche flat six) and transaxle (901), I know I've seen some cool modified jacks to do this but cannot find them now, any and all help appreciated...
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,464 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Don't use a jack. I do not like the idea of jacking the car up high, then balancing the engine and trans on a jack. Instead, remove the rear wheels supporting the body with 2 floor jacks, one on each side. Slide a moving dolly under the engine (Harbor Frieght), and lower the car so the engine just touches the dolly. Remove the bolts from the engine mount and the trans mount. Raise the body high enough to clear the engine and slide it out. Much safer than partially lying under the car trying to maneuver the engine balancing on a jack.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Don't use a jack. I do not like the idea of jacking the car up high, then balancing the engine and trans on a jack. Instead, remove the rear wheels supporting the body with 2 floor jacks, one on each side. Slide a moving dolly under the engine (Harbor Frieght), and lower the car so the engine just touches the dolly. Remove the bolts from the engine mount and the trans mount. Raise the body high enough to clear the engine and slide it out. Much safer than partially lying under the car trying to maneuver the engine balancing on a jack. How do do lower the car with the dolly underneath the motor ? I’m trying to visualize this… |
Lo-Fi Version | Time is now: 20th June 2024 - 05:22 AM |
