Radio2115 |
Newbie ![]() Group: Members Posts: 8 Joined: 12-November 20 From: Colorado Member No.: 24,879 Region Association: None ![]() |
My 914 has the larger 911 brakes. However I'm confused by what the caliper ID's may mean as they are all different on each wheel. The left rear is ATE 4, The right rear is ATE 10, the left front is ATE 284 while the right front is ATE 282. Is this correct or should the front caliper id's match each other as well as the rear? I'm going to need to replace pads at some point and would like to know if this setup is correct?
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,442 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
measure rotor width / thickness...easy indicator of what you have..
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
measure rotor width / thickness...easy indicator of what you have.. (IMG:style_emoticons/default/agree.gif) solid rotor ,vented rotor ?? (there are 2 types I believe ) alloy or cast iron calipers ? do you have 911 rear handbrake setup ?,mine are 24mm 911 Carrera with 944T 4 piston calipers. A well sorted system stock will be fine even with upgraded engine to a point, my car was setup for 220hp but with my setup stops real good with a lot less power. Post some pics of your setup and you will get answers,cheers |
Lo-Fi Version | Time is now: 30th June 2024 - 04:09 PM |
