jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I let out the clutch pedal, it makes a "creaky" noise are it comes up and a feeling. Some friction accompanies the clutch return.
First noticed this when I couldn't easily start off in1st. IIRC, the pedal cluster is less than 10 years old. Where should I start ? |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
U-clamps are a hack repair. Remove the shift lever, clamp and plug weld through the tunnel side. Put a #2 Phillips in the tube to control blow through of the weld.
https://bowlsby.net/914/Classic/zTN_Trans_C...hTubeRepair.jpg |
Lo-Fi Version | Time is now: 25th June 2024 - 10:22 PM |
