jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I let out the clutch pedal, it makes a "creaky" noise are it comes up and a feeling. Some friction accompanies the clutch return.
First noticed this when I couldn't easily start off in1st. IIRC, the pedal cluster is less than 10 years old. Where should I start ? |
davenorcal |
Newbie ![]() Group: Members Posts: 29 Joined: 5-June 21 From: Northern California Member No.: 25,605 Region Association: Northern California ![]() ![]() |
Spot weld on clutch tube came apart. Probably the front weld. (IMG:style_emoticons/default/beerchug.gif) I just discovered the same thing has happened to my car. What tipped me off was the shift linkage was moving okay until I push in the clutch which causes the shift handle’s range of motion to be reduced. After inspection using the limited number of holes in the center floor tunnel it looks like just the front weld has come loose. Has anyone come up with a way to surgically secure the cable tube? I really don’t want to cut an access hole in the center floor tunnel? |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Spot weld on clutch tube came apart. Probably the front weld. (IMG:style_emoticons/default/beerchug.gif) I just discovered the same thing has happened to my car. What tipped me off was the shift linkage was moving okay until I push in the clutch which causes the shift handle’s range of motion to be reduced. After inspection using the limited number of holes in the center floor tunnel it looks like just the front weld has come loose. Has anyone come up with a way to surgically secure the cable tube? I really don’t want to cut an access hole in the center floor tunnel? What others did is just remove the shifter to get access to the clutch tube and they U shape clamp with screw (offcourse you will get 2 holes towards the driver side for the screw/nut. http://www.914world.com/bbs2/index.php?showtopic=274079 ![]() |
jim_hoyland |
Spot weld on clutch tube came apart. Probably the front weld. (IMG:style_emoticons/default/beerchug.gif) I just discovered the same thing has happened to my car. What tipped me off was the shift linkage was moving okay until I push in the clutch which causes the shift handle’s range of motion to be reduced. After inspection using the limited number of holes in the center floor tunnel it looks like just the front weld has come loose. Has anyone come up with a way to surgically secure the cable tube? I really don’t want to cut an access hole in the center floor tunnel? What others did is just remove the shifter to get access to the clutch tube and they U shape clamp with screw (offcourse you will get 2 holes towards the driver side for the screw/nut. http://www.914world.com/bbs2/index.php?showtopic=274079 ![]() I like this approach.Cars still in the shop though, so Im kinda out of the loop |
Lo-Fi Version | Time is now: 25th June 2024 - 10:30 PM |
