BeemerSteve |
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest ![]() |
I have the daunting job of clearing out my interior and cutting my tunnel open to repair the clutch tube. Does anyone have tips on doing this job? Do the fuel lines need to be taken out? Humm.......maybe I should if they're still plastic.
I appreciate all your wisdom as I'm trying to gain some on my own. Thanks!! Steve |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,014 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Beware of cutting from bottom.
Potential concerns: There are locations where the all tubes (throttle, heater cables, clutch) all run within 2-5 mm of the floor pan. See post #401 http://www.914world.com/bbs2/index.php?sho...5209&st=400 Rear brake line runs though the tunnel Plastic OEM fuel lines (if not updated) -- not only cutting initially but later on for welding up the flap (IMG:style_emoticons/default/yikes.gif) The bottom side is exposed to the elements. pinholes in welds? Use seam sealer. Better to access from dry interior in my opinion. How to locate? Here is tunnel picture -- feel free to measure & scale. Post #322 http://www.914world.com/bbs2/index.php?sho...5209&st=320 Note: in middle of the picture you will see where the brace/bracket on this donor tunnel had torn. Likewise, at front you'll see two small J-hooks that were used to attach the front of the clutch tube back to the tunnel without welding. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:16 PM |
