jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I let out the clutch pedal, it makes a "creaky" noise are it comes up and a feeling. Some friction accompanies the clutch return.
First noticed this when I couldn't easily start off in1st. IIRC, the pedal cluster is less than 10 years old. Where should I start ? |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,263 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Mine squaks too and does not come out smooth.
Not sure what is meant by "clutch cable deflection roller". Is this referring to the one mounted back on trans? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Mine squaks too and does not come out smooth. Not sure what is meant by "clutch cable deflection roller". Is this referring to the one mounted back on trans? Yes that is the one. The OE one was a nylon. We made them from Delrin, and inexpensively. $16 everyday price with the new bushing too! https://914rubber.com/clutch-cable-deflection-roller-1-1 Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 10:12 PM |
