Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I have a small annoyance that I've been putting up with when trying to start my 914. It's been this way for years, BTW. I have a theory about what is going on, but I am interested to hear yours.
My car can be hard to start. It will crank and not catch. After one or sometimes a couple of ~15 second tries at starting, it will cough when I turn the key off again. The next try it starts up. So, any theories about what is causing this? I see two primary paths for this sort of failure; fuel or spark. --DD |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Are you saying that the instant the key returns to the on position it coughs like it wanted to start? If so I'd be curious as to the voltage at the coil when cranking.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Are you saying that the instant the key returns to the on position it coughs like it wanted to start? If so I'd be curious as to the voltage at the coil when cranking. I had an old VW Rabbit that did this. Was a bad ignition switch, no power to the 15 circuit while cranking. Sometimes I could turn the key far enough to start cranking and then back off slightly and it would catch and start. Jim |
Lo-Fi Version | Time is now: 1st July 2024 - 01:33 AM |
