Curious annoyance, -- I have a theory; what is yours? |
Dave_Darling |
Apr 4 2022, 09:49 PM
914 Idiot Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I have a small annoyance that I've been putting up with when trying to start my 914. It's been this way for years, BTW. I have a theory about what is going on, but I am interested to hear yours.
My car can be hard to start. It will crank and not catch. After one or sometimes a couple of ~15 second tries at starting, it will cough when I turn the key off again. The next try it starts up. So, any theories about what is causing this? I see two primary paths for this sort of failure; fuel or spark. --DD |
76-914 |
Apr 4 2022, 10:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Are you saying that the instant the key returns to the on position it coughs like it wanted to start? If so I'd be curious as to the voltage at the coil when cranking.
Dave_Darling |
Apr 5 2022, 12:27 AM
Sounds like fuel to me. How long does it take you to build proper rail pressure? Also what motor/injection? Fuel pressure comes up within the first few seconds of cranking. The car is a 2.0 liter (1974) with D-jet injection. Are you saying that the instant the key returns to the on position it coughs like it wanted to start? If so I'd be curious as to the voltage at the coil when cranking. That is correct, when I turn the key off it gives one cough as if there was a single combustion event. After it does that it will start normally. I am suspecting the ignition as well, but I haven't yet measured the coil voltage when it is in its failed state. I hadn't considered the ignition switch; that is a good thought!! --DD |
Spoke |
Apr 5 2022, 01:04 PM
Jerry Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
That is correct, when I turn the key off it gives one cough as if there was a single combustion event. After it does that it will start normally. After cranking and letting off the starter to turn the key off, you pass by the RUN position which is when the engine coughs. So as you discontinue the cranking, the key goes: START -> ON -> OFF. Will the car start if after an abortive cranking, what if you stopped at RUN instead of going completely to OFF? |
Lo-Fi Version | Time is now: 1st July 2024 - 12:43 AM |
