jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I let out the clutch pedal, it makes a "creaky" noise are it comes up and a feeling. Some friction accompanies the clutch return.
First noticed this when I couldn't easily start off in1st. IIRC, the pedal cluster is less than 10 years old. Where should I start ? |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Do you have problems grinding gear changes, particularly going in 1st or reverse? Because of the tension on the clutch cable it can transmit noises.
Starting front to back, it could be: clutch pedal bushings roll pin on the pedal pivot shaft broken front cable trunion broken clutch cable tube pulley, or pulley bushing rear cable trunion throw out fork cup bushing for TO fork throw out bearing |
jim_hoyland |
Do you have problems grinding gear changes, particularly going in 1st or reverse? Because of the tension on the clutch cable it can transmit noises. Starting front to back, it could be: clutch pedal bushings roll pin on the pedal pivot shaft broken front cable trunion broken clutch cable tube pulley, or pulley bushing rear cable trunion throw out fork cup bushing for TO fork throw out bearing No grinding during gear changes. Thanks for the list.At first I thought the sound/friction emanated from the pedal assembly. It’s not old, and BS assured me the bushings are brass. Cars at my local shop waiting it’s turn. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:27 PM |
