"Trailer-hitching" bucking problem, Rapid detrioration from running perfectly |
boxster914 |
Apr 12 2022, 11:18 AM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
Hi everyone
My perfectly running 71 914 1.7 D-jet has deteriorated rapidly this past week. Early in the week I noticed what felt like a power drop out during a drive. It was very slight and only happened once and I wasn't sure I didn't cause it by unconciously lifting off the gas. The next drive it happened a few times and was more pronounced. It was then that I knew this wasn't an imagined problem. On the third drive it was like a bucking bronco, surging and stopping and the engine cut out a few times. It was undriveable. Today it will start but won't run. The engine cuts out when I try to rev it and the red light comes on. I've done some searching here but haven't been able to draw any conclusions or come up with an actionable strategy to diagnose the problem. I'm seeing people trace it to spark plug wires, air fuel ratios and bad distributors. Is there a step-by-step process that you can recommend for me to get to the cause of this? (I'm a newb so I probably will need help with abbreviations like AFR, TPS, etc.) Here is a video of it's rough idle yesterday when it was still running. https://youtu.be/n61CP6O8UgM |
wonkipop |
Apr 12 2022, 06:41 PM
Advanced Member Group: Members Posts: 4,440 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
thanks for putting up that video.
its hunting as its trying to idle. i'd go looking carefully over fuel first. check the filter. check the fuel pressure if you have a guage and can do it easily. i've got a similar thing mine does when it gets warmer here. and its sounds just like that. i think in part is due to having a rhd car. took me a long time to work out what it was. without going into detail too much what happens is my fuel overheats due to the very small volume of fuel in the circuit (the bulb at bottom of tank is way smaller in a rhd car). combined with a new fuel pump in original position it can cause bubbling in the lines etc and fuel starvation. fill the tank up to halfway and its gone just like that. only in hot weather. but its exactly that kind of hunting. so i would go there first. not saying your problem is that, but not getting adequate fuel through will do something very similar. an air leak in a L jet will also give you that but tends to go up and down in revs a bit more than that. not really in the know about d jets and air leaks etc. but that sure sounds like fuel issue from your vid. it could be that its got clogged injectors, but the only way to know for sure is to pull them and get them tested. maybe leave that until a bit further along. good luck with it. stay methodical. all other suggestions above are correct. just go through everything one thing at a time. |
Lockwodo |
Apr 12 2022, 07:24 PM
Member Group: Members Posts: 202 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
thanks for putting up that video. its hunting as its trying to idle. i'd go looking carefully over fuel first. check the filter. check the fuel pressure if you have a guage and can do it easily. i've got a similar thing mine does when it gets warmer here. and its sounds just like that. i think in part is due to having a rhd car. took me a long time to work out what it was. without going into detail too much what happens is my fuel overheats due to the very small volume of fuel in the circuit (the bulb at bottom of tank is way smaller in a rhd car). combined with a new fuel pump in original position it can cause bubbling in the lines etc and fuel starvation. fill the tank up to halfway and its gone just like that. only in hot weather. but its exactly that kind of hunting. so i would go there first. not saying your problem is that, but not getting adequate fuel through will do something very similar. an air leak in a L jet will also give you that but tends to go up and down in revs a bit more than that. not really in the know about d jets and air leaks etc. but that sure sounds like fuel issue from your vid. it could be that its got clogged injectors, but the only way to know for sure is to pull them and get them tested. maybe leave that until a bit further along. good luck with it. stay methodical. all other suggestions above are correct. just go through everything one thing at a time. Hi wonkipop. My '74 2.0 with FI is having the same symptoms boxster914 and you have described. You're reminding me that I've observed very small bubbles in my fuel line. Here's what happened: I replaced the fuel filter which of course drained the line to the engine, so I wanted to purge the fuel line of trapped air. I separated the fuel line at the cold start valve and attached a clear tygon line which I put it into a clear jar, then bumped the fuel pump (by turning ignition on and off). I could see bubbles traveling through the tygon tubing, which I expected. Thing is, I repeatedly turned the fuel pump on and off and I continued to get very fine bubbles in the line. I'm in California where the ambient temp is around 75. The car has a 2 port fuel pump installed below the fuel tank. The missing happens when the car is warming up so I don't think this is a fuel heating up issue. I'm wondering if I have some sort of leak in the fuel line, something that's letting air in but no fuel out as far as I can tell? By the way, the tank is near full and I verified fuel pressure is correct and does not fluctuate when the missing occurs. |
wonkipop |
Apr 12 2022, 07:52 PM
thanks for putting up that video. its hunting as its trying to idle. i'd go looking carefully over fuel first. check the filter. check the fuel pressure if you have a guage and can do it easily. i've got a similar thing mine does when it gets warmer here. and its sounds just like that. i think in part is due to having a rhd car. took me a long time to work out what it was. without going into detail too much what happens is my fuel overheats due to the very small volume of fuel in the circuit (the bulb at bottom of tank is way smaller in a rhd car). combined with a new fuel pump in original position it can cause bubbling in the lines etc and fuel starvation. fill the tank up to halfway and its gone just like that. only in hot weather. but its exactly that kind of hunting. so i would go there first. not saying your problem is that, but not getting adequate fuel through will do something very similar. an air leak in a L jet will also give you that but tends to go up and down in revs a bit more than that. not really in the know about d jets and air leaks etc. but that sure sounds like fuel issue from your vid. it could be that its got clogged injectors, but the only way to know for sure is to pull them and get them tested. maybe leave that until a bit further along. good luck with it. stay methodical. all other suggestions above are correct. just go through everything one thing at a time. Hi wonkipop. My '74 2.0 with FI is having the same symptoms boxster914 and you have described. You're reminding me that I've observed very small bubbles in my fuel line. Here's what happened: I replaced the fuel filter which of course drained the line to the engine, so I wanted to purge the fuel line of trapped air. I separated the fuel line at the cold start valve and attached a clear tygon line which I put it into a clear jar, then bumped the fuel pump (by turning ignition on and off). I could see bubbles traveling through the tygon tubing, which I expected. Thing is, I repeatedly turned the fuel pump on and off and I continued to get very fine bubbles in the line. I'm in California where the ambient temp is around 75. The car has a 2 port fuel pump installed below the fuel tank. The missing happens when the car is warming up so I don't think this is a fuel heating up issue. I'm wondering if I have some sort of leak in the fuel line, something that's letting air in but no fuel out as far as I can tell? By the way, the tank is near full and I verified fuel pressure is correct and does not fluctuate when the missing occurs. different problem. not sure how air bubbles would be forming in yours at ambient. after the fuel pump? the original three port fuel pumps actually use the little sliding valve thats in the head of the pump to release air bubbles and send them off down the return line to the fuel tank (the return line being the line used to blow excess pressure out of the fuel pump). you need a diagram of the port assembly to understand it. more modern in line type pumps should be releasing air bubbles back through the pressure side port into the fuel pump. if there is bubbles in the line after the pump the pump is not good. bubbles can be in the line before the pump and can be there for all sorts of reasons. heat etc. but should not be there after pressurization. mine is related to actually running out in traffic. sitting at the lights, where the car, since its virtually original in all respects regarding engine etc, idles hotter. the L jets were/are known for idling hot due to retarded ignition for emissions at idle. so if its a hot day here, and by that i mean 90F + (in imperial) i think the fuel starts to boil in the line before the pump which is under the engine in original spot. (i have steel lines now which i think exaggerate the issue compared to original plastic lines). the reason it can boil is if the fuel volume gets smaller - enough of the fuel recirculating does not gain from a sufficient heat sink in the fuel tank itself. the bulb like area at the bottom of the fuel tank is reduced to half the size it is in a lhd car. soon as i increase the fuel volume by taking the tank to half full the problem goes away as the fuel volume decreases the fuel temp enough to keep it under the threshold in the line before the pump. it happens in my car if i get down to 1/4 of a tank on hot days. so mine is not so much bubbles after the pump but pressure drops due to interrupted supply flows. i'm not saying this is boxter's problem. its just where i would start first with his car if i was him. just making sure he is getting fuel ok. if boxster wants to solve his problem r_bowie's advice is very good. go to the thread. the other thing boxster needs to do is down load the factory work shop manual. its got all the trouble shooting pages etc in it to methodically go through. as soon as Van got hold of that manual he was off and running. i think its the guy who has the 914/6 GT website. he has the manual there i believe. i'd have to check again. you need a good manual if you are sitting at home trying to solve these things. EDIT. i don't have the problem of the car dying when i give it to it. which is boxter's problem. his was able to still idle but as soon as he gassed it, it died. and now it won't go. so i would be starting with fuel first and tick that off the list. could be his fuel pump died. usually they just go bang. but a guy i know with a big citroen had his fuel pump go gradually. and it did more or less what boxster is describing. after he pulled it out, he tested it and it still ran but it just wasn't building pressure. something had let go inside it in the pump section itself rather than the motor. unlike me he never did the can opener trick to find out what it was. just replaced his fuel pump and moved on. with the original three port style fuel pumps that 914s had they just go bang. cease operations. usually due to chewing up the brushes or something in the motor finally after 1 million miles. but a more modern fuel pump can fail gradually or give more warning its on the way out. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:00 AM |
