seatosummit |
Newbie ![]() Group: Members Posts: 19 Joined: 23-December 20 From: Berkeley Member No.: 25,012 Region Association: None ![]() |
Hi -
I've just completed an EV conversion on my Porsche 914, so all of the internal combustion related parts are for sale. It was converted to a single weber carb by a previous owner. The previous owner rebuilt the engine less than 1000 miles ago. New pistons, pushrods and seals all around. Includes the functional alternator, tin, heat exchanger and exhaust from the 914. I have the factory blower motor also that I can include if desired. The case serial number is W0127222 - I looked it up and this from a 71 1.7L. I contacted the PO and assures me that that is just the case (which were all interchangeable) and the internals are of the larger displacement. Rebuilt 2.0 Liters are roughly 5k, so the mismatched case is why I am pricing lower than market. This will fit in the bus of the same era and no doubt a number of other VWs with a bit of effort. If you are going to use the carb that is installed, you should replace the rubber injector runners, as one of those was ripped during the removal process (see photo). I also have a fuel refurbished fuel tank with new fuel level sending unit, as well as 6 month old tangerine racing SS fuel lines. $150 for each. Linked CL ad has many more photos. Can send a video of it running before I pulled it in January. Thanks for looking! Cash and local pickup preferred. Could ship if buyer handles logistics. CL Ad |
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Just so it's clear, the heads are four-bolt so if they're 2.0L heads then they're from a bus, not a 914. You can also make a 2.0 motor with smaller displacement heads.
To fit a bus it would require different exhaust, tin and flywheel bits. The dipstick location can be a bummer for bus owners too. Good luck with the sale! |
seatosummit |
Just so it's clear, the heads are four-bolt so if they're 2.0L heads then they're from a bus, not a 914. You can also make a 2.0 motor with smaller displacement heads. To fit a bus it would require different exhaust, tin and flywheel bits. The dipstick location can be a bummer for bus owners too. Good luck with the sale! Ahh, useful notes. Thank you! |
Lo-Fi Version | Time is now: 29th June 2024 - 03:13 AM |
