bmtrnavsky |
Member ![]() ![]() Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region ![]() |
My 914 has been sidelined since 2012 for a number of reasons but was parked not running. Pulled it out of mothballs and hauled it over to the local vintage Porsche mechanic who said my impulse sender had no signal. He said he was unable to source parts for it and was unsure if replacing that part would get it back on the road his recommendation was to convert to Weber 40's. I'm not rich so I understand his hesitancy to open what could be a very expensive can of worms.
So here is where my questions start I'm just looking for a solid running reliable car that I can drive on trips and maybe autocross 2-3x per year. anyone have a source on the impulse senders? can they be rebuilt? Is the Carb it advice good? I have a basically stock 2.0 with hydraulic lifters and a very mild cam. Will I have to change my cam to convert it? what's the best carb? I have seen 34's 40's and 44's people seem to do all three are there pros and cons to each setup? Can I get this conversion done for around $1500 in parts and is it a achievable project for an average mechanic? I suck with electrical but I have plenty of tools and am not afraid to learn as I go. I have done head gaskets and other mid level projects before. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,019 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
. . . . local vintage Porsche mechanic who said my impulse sender had no signal. The blinker fluid is also hard to come by. Signed: Resident smart (IMG:style_emoticons/default/bootyshake.gif) Time for a new mechanic in my opinion. I've been in the automotive industry for 27 years and have no idea what is meant by an impulse sender in the context of a 914. It could be interpreted to be any sort of Hall Effect sensor (Crankshaft, camshaft, speedometer, ABS sensor, etc.). Of which, the 914 Fuel Injection system has zero. Could it mean: Injector trigger points? Maybe -- but can be obtained with some work. Ignition points -- These are definitely available so suspect that isn't what he means. Source for trigger points in a pinch - not completely unavailable. ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 09:04 PM |
