Subaru swap stories?, where's fiid? |
lapuwali |
Jan 3 2005, 01:53 PM
I know Fiid was doing one of these, anyone else in progress or complete?
After doing the contortionist trick of adjusting valves with the exhausts in place a couple of times, I'm in the middle of pulling the HEs off my 1.7 to replace a pair of exhaust studs, and reminding myself how much easier the job would be if the exhausts were off, but thanks to the stock heater system how big a hassle that is. I hate exhaust studs pulling out (No. 3 cylinder, as usual). And all this trouble for only 80hp. 140hp or so from a water-cooled engine with hydraulic lifters (or 20K mile valve adjustment intervals) is starting to sound pretty good right now. If it were any easier to run water lines, I'd be all over this already. |
mattillac |
Jan 11 2005, 07:33 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
scott, what do you think about cutting and rewelding the intake manifold so that the throttle body faces the front of the motor? do you think it would be in the way of anything else that's on the motor?
for any of the welders on the forum, is it ok to weld cast aluminum? i hear that aluminum isn't the easiest metal to weld, but would it be harder if the aluminum has already been cast as a manifold? |
Lo-Fi Version | Time is now: 28th September 2024 - 08:59 AM |
